Vibration coming to a stop at about 800rpm??
Old Sep 22, 2020 | 09:08 AM
mcu's Avatar
mcu
Default Vibration coming to a stop at about 800rpm??
When coming to a stop i feel this vibration always around 800rpm. I hope it's not the tranny or differential. Any suggestions how to troubleshoot that and what to look at? Anyone else experience something similar?
Old Sep 22, 2020 | 03:47 PM
check your driveshafts for wear. could also check motor and tranny mounts.
Old Sep 22, 2020 | 11:43 PM
mcu's Avatar
mcu
whats the best way to check driveshafts? I guess mounts is by physical inspection only?
Old Sep 23, 2020 | 12:19 PM
check the universal joints for play on the ends of the driveshafts. you can also check the shaft straightness with a long flat ruler on its edge against the shaft in a few spots around the shafts circumference and see if there is any deflection (light peeking through the two mating surfaces... ruler or straight edge and shaft tube).
the mounts you would have to inspect... yes
Beardz
Jul 6, 2020 08:54 PM
daddyhodge
Mar 3, 2017 05:33 PM
swenski71
Aug 15, 2014 01:28 AM
tfc09h3
Aug 10, 2010 09:13 PM
Blaser
Aug 8, 2009 09:14 PM
