unknown driver car will not starting Hummer h2 04
Old Jun 16, 2021 | 01:57 PM
Shajemister's Avatar
Default unknown driver car will not starting Hummer h2 04
Hello friends Martin here from Sweden I have a very big problem with my hammer on the picture,
I have been working on this truck for about six months in my befriends work shop.
I have sandblaster whole body,
remove all deaths from the wiring, and reconnect them.
when I was trying to drive it out into a mechanical shop, everything works fine,
but then after we were putting the last layer liner on the body.
and I went running out of gas.
I did put new gas in it and tried to start the truck,
**** I only get up unknown driver.
The car is starting up for approximately three seconds and then die.
we have checked the fuel pump.
we have checked fuse. And signals and everything to the injectors.
and now I have been ordering new door modules swish for the door panel in the front.
because it doesn’t work to lock or unlock the door.
and she doesn’t work the key or the OBD plug.
I can’t get any signal to the unit.
please can someone help me I am prepared to pay if someone give me a solution that’s not working!
I have disconnected Front wheel sensor.
I had a try to do the programming.
I have put extra ground.
on all three spots.
nothing works!
Old Jun 16, 2021 | 11:09 PM
check your ground on the chassis located under the truck near the front of the drivers door. maybe the coating does not let it make proper ground.
PanchoH2
Feb 26, 2021 04:13 AM
Karenswann
Feb 22, 2021 09:11 AM
janet
Mar 14, 2011 11:36 AM
Linus Gump
Jul 8, 2007 07:38 AM
Greenblade
Jun 23, 2006 02:13 AM
