truck lean
Old Mar 18, 2008 | 08:15 AM
IMPERIAL's Avatar
Default truck lean
newbie here,,, does anyone have an h2 that leans to the right. is it just me,,, maybe because the rig is wide and makes the road crown feel different. The dealer said they all lean a little...factory tolorence 1/2" what ya think...
thanks Larry
Old Mar 18, 2008 | 08:30 AM
HumminNBoatin's Avatar
Default RE: truck lean
Welcome to the Site. You will find a ton of info here.
I would get a tape measure and recored the height of each wheel well. Do it in your garage so you have a flat surface. I would assume the drivers side should be just a bit higher as the engineers wanted to compensate for the 32 Gallon gas tank and the weight of the driver to level it out.
Eric
Old Mar 22, 2008 | 08:35 AM
IMPERIAL's Avatar
I have measured and it is at the center of tire from ground to body. The truck is quarter to half inch off. Could some others measure and post your results. Thanks.
Old Mar 22, 2008 | 09:36 PM
Hmmmm....I never noticed before???
Old Mar 22, 2008 | 09:51 PM
finall's Avatar
Likely well within tolerance. I know on the Jeeps, 1" difference between corners was considered normal. I had this issue on our last Jeep Grand Cherokee.
I would say 1/4" you can not measure. This is because tire pressure or uneven tire wear will account for 1/4" by itself. Check these first. Then, if you were off by more thanb 1", you would have a broken or weak spring. Otherwise you are likely OK.
Old Nov 20, 2020 | 02:30 PM
Dash J Champion's Avatar
Default Hummet h2 lean
thanks Larry
My h2 leans a little to the left,like a 1/2 "
Old Nov 20, 2020 | 05:05 PM
@Dash J Champion I'm not sure that anyone from over 12 years ago really cares about this thread anymore.... Especially considering that the member you replied to has not been here a single time since they posted about it back in early 2008.
sneakypigeons
Dec 5, 2022 10:50 AM
rpalatine
Mar 24, 2013 03:40 PM
Alex2012
Oct 1, 2012 01:53 PM
Keithmo
Jan 10, 2009 09:11 AM
bmbenear
Jan 1, 2007 05:56 AM
