Trouble starting, sometimes
Old Oct 1, 2021 | 03:26 AM
HellHoof's Avatar
Default Trouble starting, sometimes
My new to me 2008 sometimes struggles to start. It cranks hard like normal, but acts like it isn’t getting any fuel. Sometimes after 5-6 seconds of cranking it finally fires up, others I’ll stop and let it sit for 10 seconds, try again. Then it fires up after 3-5 seconds of cranking.
When it does eventually start it chugs up to idle, but then runs perfectly fine after that.
About 90% of the time it fires RIGHT up. But the other times it struggles.
Are there any common things to try looking into first?
2008, 89k miles.
Old Oct 1, 2021 | 07:32 AM
legerwn's Avatar
I would start with checking fuel pressure at crank up and for a leaking injector
Neal
Old Oct 1, 2021 | 10:05 AM
is it temperature dependent? when cold or when hot? that could be an intake leak issue. also the coolent temp sensor on the front drivers side head is very important i guess check its temp reading with a scan tool and make sure it's connector is not loose. if you can get a fuel pressure gauge you might also want to monitor the fuel pressure. other things that can extend the crank are the cam and crank position sensors.
Old Oct 1, 2021 | 04:06 PM
Cold, cycle the key on/pause/off several times without cranking, then check time for startup. Post the results.
Old Oct 1, 2021 | 05:14 PM
My 3 is 3-5 revolutions @ startup:
Old Oct 3, 2021 | 11:10 PM
HellHoof's Avatar
Next time it happens I’ll cycle the key and try to listen for the fuel pump without cranking. I haven’t noticed the security light being on during this time.
As far as I can remember it hasn’t ever done it when cold. Only warm (driven in past 30 mins - 2 hours).
I don’t have any check engine lights on, but I guess that doesn’t rule out any sensors.
But it’s so intermittent, and I don’t drive it often, it may be a day, or 2 weeks before it happens again.
K0PIR
Oct 11, 2021 02:43 PM
jchummer
Dec 28, 2012 06:08 PM
Pdmiller
Sep 25, 2012 05:40 PM
tygo
May 8, 2012 12:26 PM
BobsHummer
Apr 11, 2011 06:32 PM
