Transmission problem
Old Dec 28, 2023 | 10:05 AM
Hummer2008.'s Avatar
Default Transmission problem
Hello,
the gearbox hold on the 1st gear and when I turn it off and on it shifts normally and after minutes back to the same problem again (H2 6.2 2008 6speed)
Old Dec 28, 2023 | 10:55 AM
H2-SUT's Avatar
If you have a GM Tech2 tool you should be able to test the actuation of the solenoid. BTW, when was the last fluid/filter replacement? A clogged up filter that causes low line pressure can cause a bunch of issues for the 6L80.
Old Dec 28, 2023 | 11:26 AM
Will test it ,I changed the body valve tcu only
Old Dec 31, 2023 | 08:59 PM
Gavin Costigan's Avatar
My transmission is pretty new and it occasionally does the same thing. Idk what it is. It just throws a fit all of the sudden. It only happens when manually selecting 1 or 2 (the numbers on the shifter not tap up/down on the wheel).
last time it was really bad. I went from 1-2 and when it finally engaged second it chirped all 4 tires.
how many miles are you at? Could be time for a fluid and filter change?
side note: a tin can would have been a better option for the h2 than the 6l
edit: I now see it’s a constant issue for you. Check fluid level, Inspect wiring and do a filter/fluid change and inspection but chances are to put it nicely… you’re f*cked.
vinfecent
Jun 17, 2023 01:31 PM
Hummer2008.
Jan 13, 2023 11:28 AM
flashinq
Mar 6, 2022 07:51 PM
franzu666
Nov 3, 2013 11:17 AM
mrigor
Aug 30, 2013 01:29 AM
