Trans cooler lines and oil cooler lines
Old Jan 14, 2022 | 08:08 PM
Back40coffee's Avatar
Default Trans cooler lines and oil cooler lines
got rid of the leaking crimped lines
Old Jan 15, 2022 | 08:30 AM
calif phil's Avatar
Those are not going to leak. Good job! Look pretty stiff, might be worried about them not flexing enough and causing the aluminum pipe to crack.
Took care of my engine oil cooler lines by throwing them in the trash and they were not even leaking.
Old Jan 17, 2022 | 01:12 PM
Sam!'s Avatar
you removed lines and cooler altogether?
Old Jan 17, 2022 | 01:13 PM
Sam!'s Avatar
Old Jan 17, 2022 | 02:05 PM
Default Lines
I didn't sam Phil will have to answer that one .
Old Jan 18, 2022 | 08:02 AM
calif phil's Avatar
I installed a new GM radiator as preventive maintenance, then purchased the GM oil block off plate for the engine oil cooler line ports, removed the engine oil cooler lines completely, the transmission cooler lines were left stock and hooked up to the new radiator. I don't tow enough to warrant an oil cooler and like the peace of mind, knowing that I don't have oil cooler lines to leak or suffer major engine damage if a catastrophic failure occurred.
bambamninja
Jun 18, 2021 10:40 AM
drewandsteph
Jan 22, 2018 07:50 AM
heyttsguy
Jul 16, 2016 02:29 PM
msailors
Apr 5, 2015 07:21 PM
ghawthorn
Feb 20, 2013 09:10 PM
