Trailer Brakes for those with Factory/Dealer Installed Off-road Lights (Solved)
Old May 27, 2023 | 02:48 PM
clsimmon's Avatar
Default Trailer Brakes for those with Factory/Dealer Installed Off-road Lights (Solved)
I have a 2003 H2 and was not getting trailer brake signals to the 7-way plug on bumper. I learned that the dealer not only used the port under the dash for brush guard ligjts, they also used the circuit #47 known as "trailer auxiliary supply voltage" to feed the power for the lights through the firewall. After hunting for a single wire plug above the front left wheel well, known as plug c105, I saw there the blue factory wire they disconnected and replaced with a wire going to the lights on the brush guard.
After unplugging my brush guard lights and plugging back in the factory wire, my trailer brakes worked flawlessly.
I hope this saves someone else the 3 hours I spent having to chase this down.
Old Aug 7, 2023 | 08:47 PM
StevierayH2's Avatar
Thank you so much for this. I had the same issue. Plugged the blue wire back in and everything works. You are a lifesaver. 👍🏻
Old Aug 8, 2023 | 10:06 AM
if you wire in a 5 pin relay you would be able to toggle between the 2 functions. wire what you want to be default on, to the normally closed part of the relay and the secondary function to normally open pins
Old Aug 8, 2023 | 11:02 AM
Awesome, thanks again.
parabat
Jan 30, 2017 10:20 PM
odonnks
Apr 28, 2011 05:40 PM
Marauder
Dec 14, 2008 05:09 PM
dirtman
Jun 8, 2008 09:34 PM
Yankees31
Jun 29, 2007 10:18 PM
