Trailer Brakes for those with Factory/Dealer Installed Off-road Lights (Solved)
I have a 2003 H2 and was not getting trailer brake signals to the 7-way plug on bumper. I learned that the dealer not only used the port under the dash for brush guard ligjts, they also used the circuit #47 known as "trailer auxiliary supply voltage" to feed the power for the lights through the firewall. After hunting for a single wire plug above the front left wheel well, known as plug c105, I saw there the blue factory wire they disconnected and replaced with a wire going to the lights on the brush guard.
After unplugging my brush guard lights and plugging back in the factory wire, my trailer brakes worked flawlessly.
I hope this saves someone else the 3 hours I spent having to chase this down.
if you wire in a 5 pin relay you would be able to toggle between the 2 functions. wire what you want to be default on, to the normally closed part of the relay and the secondary function to normally open pins
Awesome, thanks again.
Marauder
Dec 14, 2008 05:09 PM
