Tire replacement
Old Dec 27, 2019 | 01:08 PM
jtomasino's Avatar
Default Tire replacement
Group, I need to replace tires on my 07 H2 SUT. The torsion key(s) were adjusted to raise the front end to have a more level stance. As we all know the stock tire height is 35s. I would like to bump up to 37s but not certain if I will encounter rubbing in the front end. I have read that some say yes and some say no. Can someone who has 37s with adjusting the keys tell me for sure. thx - joe
Old Dec 27, 2019 | 01:47 PM
LoJac963's Avatar
Some say yes and some say no because each H2 seems to be different. With cranked keys I would think 37s would fit fine. My stock 35s rubbed on the sway bar until I went through my front and and readjusted everything. I also would not go with larger tires without upgrading the tie rods.
Old Dec 27, 2019 | 01:59 PM
jtomasino's Avatar
Thx for responding. My 35s do not come close to rubbing. Maybe I should just stay with 35s.
Old Dec 27, 2019 | 04:18 PM
I have 37x13.5 on mine with cranked (reindexed) torsion keys. When backing up at an angle it rubs the tiniest but but not enough that anything would ever be damaged - zero in the rear. If I had 37x12.5 instead of the 13.5 wide they probably would not rub at all. On mine anyways. As LoJac mentioned, it seems to be hit and miss. Some people report rubbing while others do not. Will also depend on your wheels as well. Mine are aftermarket - not sure of the offset and backspacing off the top of my head though.
Old Dec 27, 2019 | 04:29 PM
jtomasino's Avatar
Ok... I am running with the stock wheels and would do 12.5 rather than the 13.5.
Old Dec 27, 2019 | 07:23 PM
Narrower tires better in snow and on ice because they get better linear traction by penetrating the snow.
Old Dec 27, 2019 | 08:00 PM
legerwn's Avatar
I'm running a true 37" x 12.5" tire with the 08 OEM 20" wheels and do have a slight rub on the frame at full lock turn. I do have a leveling kit (keys) on my truck and have the front raised as high as it will go without causing issues with suspension travel. I do plan to install Cognito upper A-arms which will allow me to raise the front more once I get the engine back in.
The wheels will have a large impact on where the tires are in the wheel well,
Neal
Old Dec 31, 2019 | 03:22 PM
alamry's Avatar
i'm running 38" X 13.5 but had to go 2" body lift with zero rubbingz
hnijhar
Nov 18, 2019 01:00 AM
H2Sut06
Private 'Wanted' Classifieds
Apr 7, 2019 08:57 PM
tripper
22
Dec 2, 2015 02:44 PM
psych0
Mar 29, 2010 04:14 PM
GorillaH2
Aug 17, 2007 10:11 PM
