Tire Carrier Latch Lever
Old Sep 1, 2021 | 11:30 AM
oceanbrave's Avatar
Default Tire Carrier Latch Lever
Not exactly sure what to call this, but one of my friends has one that looks like below:-
Like me it's seen better days
Does anyone know what the proper name is and if they are available? I can't seem to find anything.
Also is this typical?
Mine I had bead-blasted and powder coated as the rust was only superficial, must be the weather in UK and salt on roads.
Cheers..
Old Sep 1, 2021 | 11:48 AM
legerwn's Avatar
Spare Tire Compartment Cover Latch
Part Number: 25864506
Supersession(s): 15894723; 20784413
They are pricy if you can find them
Neal
Old Sep 1, 2021 | 11:58 AM
oceanbrave's Avatar
It doesn't look like you can buy just the top bit i.e.
Is this a common issue?
I was asked if i could get one made, 10-off yes but 1-off would cost way too much..
Old Sep 1, 2021 | 01:22 PM
maybe 3D print a cap cover clean up what you can and epoxy it on or maybe a few rivets on what is left. or maybe just some thin aluminum riveted on
Old Sep 2, 2021 | 02:12 PM
oceanbrave's Avatar
Indeed I know someone here who's done exactly that, it kind of looked OK and worked which is the main thing ✔️
Old Sep 5, 2021 | 11:23 AM
ben1272's Avatar
If you preserved the pivot pin and spring, the rest would not be too bad for a weld fabricator to make. Might even be able to just cut and weld on a new top and side piece....easy to cut on a bandsaw and weld at home.
I would not cover it up with plastic and leave it....now is the time to fix it. Soon it will fail on you, likely when you need it most!
Old Sep 5, 2021 | 06:13 PM
Definitely cutout the rust, then spot weld type 316 sheet metal, or take it to an auto body shop for repair.
AlZabra
Private 'Wanted' Classifieds
Sep 1, 2019 08:54 AM
mcioci
Jul 19, 2018 09:00 AM
mcioci
Jul 1, 2018 11:06 AM
Morgan Kushniryk
Apr 13, 2016 09:54 AM
markdoddridge
16
Apr 27, 2015 07:03 AM
