These tires good to put on?
Old 05-05-2022, 06:56 PM
flashinq's Avatar
Default These tires good to put on?
Bought some used 37 tires to put on the H2 and wondering if these are safe to drive on because of the creasing are tears. I don’t know much about tires, was hoping someone can help me.
https://youtube.com/shorts/9B9LFvqDE3o?feature=share
Old 05-05-2022, 07:02 PM
waltham41's Avatar
That isn't anything imo that is dangerous as far as the tire failing. Someone was rough breaking the tire down.
Otoh it may be a challenge to get the tire to bead/seal on the rim and hold air because of that damage.
Ask your local used tire shop if they think the tires will seal and hold air. They can see the tires in person and give you a better opinion.
Old 05-05-2022, 08:23 PM
What are the LAST 4 DOT serial number digits?
Old 05-05-2022, 08:25 PM
flashinq's Avatar
It says 4020
Old 05-05-2022, 08:36 PM
Production date 40th week 2020= GOOD. However, the bead is damaged.
Old 05-05-2022, 08:38 PM
flashinq's Avatar
So no good I have 4 and all kind of like that, what should i do?
Old 05-05-2022, 08:42 PM
Get them checked/mounted by a reputable tire shop, they will use a bead sealer and check for leaks, if they hold pressure, drive on.
Old 05-05-2022, 11:18 PM
Sam!'s Avatar
Should be fine to install, for extra piece of mind if wanted put repair sealant on the loose pieces and a coat over the missing pieces. then bead sealer when they are getting mounted.
Old 05-06-2022, 08:18 AM
calif phil's Avatar
Mount them up, that is not too bad.
Old 05-06-2022, 04:13 PM
flashinq's Avatar
Appreciate you sam, hummerz and the rest of you guys! Very helpful!
Quick Reply: These tires good to put on?
