Sweet spot for H2 tire pressure. 2003
Old Nov 24, 2023 | 08:21 AM
Fonzie's Avatar
Default Sweet spot for H2 tire pressure. 2003
I’ve been trying to find the sweet spot for my Hummer H2’s tire pressure. I haven’t pumped up to 39 psi now but the ride is kind of hard. I thought about lowering them, but then the gas mileage will be less and I don’t want them
under inflated. What tire pressure are most of you running?
Old Nov 25, 2023 | 01:37 AM
finall's Avatar
You can not have smoother ride with higher tire pressure. Pick one.
I run 45-50 psi on TA KO2s for less body lean and better mileage and MUCH better front tire tread wear.
Old Nov 25, 2023 | 08:32 AM
calif phil's Avatar
I run 35 psi in my TA K02s
Old Nov 25, 2023 | 03:48 PM
Default Change the shocks
Higher tire pressures have many advantages including better fuel economy, longer tread life, increased load capacity, improvement in steering response, and cornering stability,etc. Also, increase pressures for the cold months to make up for lower temperatures causing lower air pressure(for every 10° Fahrenheit change in air temperature, tire pressures will change about 2%). Change the shocks for a more comfortable ride.
hummin along
May 29, 2018 07:30 PM
ATX_H3
20
Nov 22, 2013 02:08 PM
bettrthntiger
20
Oct 22, 2009 08:18 PM
Kendrick
Jul 28, 2008 06:57 AM
Sugardaddy
Aug 9, 2006 06:36 PM
