Stock ride height ?
Old May 17, 2025 | 03:41 PM
United Timber's Avatar
Default Stock ride height ?
Can someone please tell me the measurement between the top of the stock size 315/70-17 tire and the bottom of the fender flare on a stock-height, non-lifted H2?
I suspect my mechanic cranked the torsion bars too high when installing my Cognito UCA Kit.
I also have a 1" spacer under the rear coil springs.
Currently on my H2 the distance between the top of the stock 315/70-17 BFG KO3 tire and the bottom of the fender flare is right at 10".
I have the Cognito UCA + torsion bar keys kit with Bilstein shocks. These front Bilsteins are made for 0" to 2.5" lift.
Thank you!
~10
~10\" between top of tire and bottom of fender flare.
A little leveled in this picture, but before Cognito UCA kit.
Old May 18, 2025 | 05:24 PM
Default Answer to my own question
Okay I will answer my own question since nobody else has.
I found an old thread on this forum through a Google search.
Responses there were 8.5 to 9.0 inches, so my 10.325 inch measurement with brand new BFG KO3 tires is well within the safe 0 to 2.5" "lift" capability of my Cognito UCA kit.
Old May 30, 2025 | 07:00 AM
Brunob00's Avatar
See this post and the specifications from @clsimmon
https://www.hummerforums.com/forum/h...-fender-46372/
Old Jun 4, 2025 | 09:46 PM
H2-SUT's Avatar
41 5/8 of an inch front, 42" rear. These measurement are from the ground to the bottom wheel opening molding on the front and rear on a level surface. This is for stock SUT with non lifted and factory sized tires but believe would be the same for the SUV too.
One note, my front suspension just barely rests on the bump stops and the "Z" height has been verified and the alignment is as close to perfect as it can be.
hnijhar
Nov 18, 2019 01:00 AM
ockie
H3 Frequently Asked Questions
37
Mar 13, 2015 10:11 AM
hummer4406
Dec 7, 2012 01:46 PM
H2Joe
May 30, 2008 12:26 PM
stallioncustoms
Jan 14, 2006 04:42 PM
