Starting problems
Old Nov 23, 2022 | 10:17 AM
Joe and jeanette's Avatar
Default Starting problems
H2 hummer will start when it sits for awhile but when I stop for a few minutes and try to start again takes 3 or 4 cranks before it starts , every time I shut it off for a few minutes , it takes awhile for it to start, any suggestions
Old Nov 23, 2022 | 10:24 AM
there are many suggestions but are there any codes or security lights on? before firing up the parts cannon.
Old Nov 23, 2022 | 10:25 AM
there are many suggestions but are there any codes ? before firing up the parts cannon.
had a coolant temp sensor code that I haven't taken care of that's it
Old Nov 23, 2022 | 10:31 AM
coolant sensor can keep the truck from starting. the PCM is highly dependent of it. it would be located near the front of the drivers exhaust manifold P/S bracket area. bolted to the head. not very big.
Old Nov 23, 2022 | 10:32 AM
Ok just picked it up and will be installing today , I'll post and update after, thanks
Old Nov 23, 2022 | 02:36 PM
zenith's Avatar
^^^^^^^^^^Yeah, what he said^^^^^^^^^^
Old Nov 27, 2022 | 08:41 PM
Changed the coolant sensor and has started every single time , thanks for the help, on another note where does the rear back door get its single from showing open and close even when it's closed, thanks
Old Nov 28, 2022 | 09:50 AM
zenith's Avatar
Here's a pretty good article explaining the door open sensors. You may want to pop your door panel off to get to the switch/sensor and clean it. If this isn't it maybe try starting a new thread to more people to chime in.
https://repairpal.com/door-ajar-warning-light
Odzihozo
Feb 4, 2022 05:49 PM
559H3
Sep 8, 2020 08:59 AM
jchummer
Dec 28, 2012 06:08 PM
darb34
Mar 12, 2008 06:58 AM
real7446
Jan 5, 2008 07:47 PM
