squeal and/or pop from front when turning
I too am have the squeeling problem while turning. It generally only happens when turning right at slow speeds when the vehicle is cold. Goes away after about 10 miles. I pulled everything off of the driver side (tire, caliper, pads, caliper frame) just to check things out. Nothing out of order. I did however notice that when I had everything back together still on the jack that there is alot of play in the entire assembly. ie: can "wiggle" the tire. Checked the passenger side as well and it does the same thing. Is this normal???
No replace wheel bearings. Buy good Eaton bearings not cheap chinese ones.
Agreed . I used cheap ones and lasted about 100k which aint bad but should last forever. The brake sensor also self destructed. Its good to get fresh bearings after a while just ti keep the sensors up as well.
Fuel Filter or Air/Fuel Delivery Issue??
mine recently started popping just a few months after i got tie rods, ball joints, upper control arms done.
i just got a mechanic to check the cv and the wheel bearing and he said there fine.
it sometimes pops on turns when cold in the morning and i feel like the steering has excess play and kinda has a pop when turning etc. i also seem to hear some noise when im driving, maybe im paranoid but it just sounds like theres some unusual front end noise..
any ideas?
any ideas?
DMW5150
Feb 20, 2015 03:29 PM
Jeff H2
May 25, 2012 01:42 PM
