Side View Mirrors Moving in Wrong Direction
Old Feb 24, 2020 | 10:18 AM
pepper's Avatar
Default Side View Mirrors Moving in Wrong Direction
When I enabled the rear view assist for the side view mirrors, the passenger side worked correctly at first. Once the vehicle was restarted the mirror did not move down when the vehicle was put in reverse, but once the vehicle was put into park or drive the mirror then tilted downward. The Drivers side view mirror is working correctly. I'm also having the same problem with drivers seat. When I enabled it for the seat to move back for easy exit, it is working in opposite direction. When I remove the key to get out of the vehicle, the seat moves forward. This all started happening after a battery charger shorted out while it was hooked up to the battery, and yes the cables were hooked up correctly. Also having trouble with oil pressure gauge not always reading and RPM's not working. Could the seat and side view mirror's all be related to cluster?
Old Feb 24, 2020 | 12:35 PM
for the seats you probably need to re adjust the exit position and same for backup mirror position then save them where you want them. the procedure is in the owners manual. the needles not working correctly is very common. you most likely need new servo motors installed into the cluster.
Old Feb 25, 2020 | 06:00 AM
oceanbrave's Avatar
Agree with Bronxteck.
If you operate the Up/Down/Left/Right controls and the mirrors move correctly they are operating normally, same goes for the driver's seat controls.
It could be the memory positions got scrambled, but not sure how, technically there is no link with the cluster.
tothemax
Nov 6, 2025 12:53 PM
Sooner1
Feb 28, 2018 07:48 PM
H2Miami
Jan 18, 2017 03:43 PM
2005H2
Jul 26, 2016 09:41 AM
Mcpousnret
Oct 28, 2013 04:36 PM
