Should I bother replacing door seals?
Old May 24, 2026 | 07:12 PM
Aldo2006's Avatar
Default Should I bother replacing door seals?
I linked a video of what's going on on my H2, I'm trying to figure out should I re buy the gutter seal at the top and get a higher quality one. or should I replace the door seal? also some advice on routing the door seals would be appreciated.
Old May 26, 2026 | 09:57 AM
it helps to pull the rubbers off and really clean the dirt and caked mud out of the channels. use a good stiff brush that can get into the crevices and some warm soapy water. if it is real bad maybe just let them soak in a bucket for a while. if the rubbers feel or look dried out tough or dull you can rub them with superlube grease to kind of re condition them for a bit.
Old May 27, 2026 | 07:10 PM
Aldo2006's Avatar
alright thanks for that I’ll give it a shot
Old May 31, 2026 | 01:53 PM
Mark R's Avatar
Good advice:
Every fall I get an old sock and a few tubes of Dioletric (Clear) Grease. Soak the sock and rub down all the door seals ..inner and outer. Prevents them for freezing shut in the cold and keeps them lube-ed . Just don't rub up against them when getting in and out of your 2.....L.O.L.
Numb
May 11, 2023 05:29 PM
dkb123
Jun 21, 2022 12:24 PM
SquareD
Nov 29, 2016 11:55 AM
DirtyH3
Jul 15, 2015 12:50 PM
gotafish
Jul 19, 2012 11:18 PM
