Replaced Driver's Seat Cushion and Cover
Old Jan 20, 2022 | 02:37 PM
coboarder's Avatar
Originally Posted by fastNYsix
How did you get your cover to fit? Maybe they're better now. I had major fitment issues with Richmond leather. I ended up sending the seat covers back, they were so terrible. I even used a new gm cushion. They claimed they pattern theirs off a new oem cover.
I didn't have a problem, I mean everything was super tight but the tighter the better to keep the creases out of the leather. I watched the youtube videos and attached the back first then the front then the sides and finally the rear corner hooks. That's too bad you had a hard time. When it was all over, I'm glad I'm not in the upholstery business as a career but the leather on my '07 looks a lot better and after 15 years the original was due for a replacement.
I looked at Katzkin leather which I have in my Jeep Wrangler but they were too expensive for a complete package + installation when all that I needed was the seat cushions.
Old Jan 20, 2022 | 08:04 PM
fastNYsix's Avatar
Originally Posted by finall
The way you get it to fit is to buy an OEM skin. Not aftermarket. Even then you may have fitment issues. The new skin needs to be STRETCHED to fit. (As you can see was not done in the OPs photo above. )
I wish I could find a new oem cover.
Old Jan 21, 2022 | 11:20 AM
Most upholstery shops use a steamer when installing to help with stretching/relaxing the leather. Also for headrests, a vacuum with a plastic bag over the foam is the trick for those to compress the foam. Getting the armrests off is a bit tricky. If looking for info like on Youtube, etc on doing it yourself, look for replacing leather on a Silverado, Suburban, Tahoe, etc as those are orders of magnitude more common and use essentially the same style seating.
finall
Nov 20, 2023 10:25 AM
finall
Dec 6, 2020 03:28 PM
Daniel Z
Jan 27, 2020 08:03 AM
hummer_on_fumes
Oct 10, 2018 12:16 PM
NC_Hummer
Nov 5, 2011 06:15 PM
