Rain guards for Windows installed
Old Jun 30, 2024 | 08:19 AM
RobertDez's Avatar
Default Rain guards for Windows installed
Trying to protect my new window switches from getting soaked when you open the window in the rain. (Like at a drive-through)
Fit perfectly, go between the weatherstripping and the door itself, took 15 minutes to install. Price is reasonable.
Tuningpros WD2-244i Dark Smoke 4 Pcs Set Window Visor (in-Channel) Deflector Rain Guard Compatible with 2003-2009 Hummer H2 https://a.co/d/02YN80EW
Old Jun 30, 2024 | 04:03 PM
Mark R's Avatar
Nice. I assume they are Weather Tech? Anyway Make sure the passenger sides are tight and not lose. I lost one from rolling the windows up and down. Got a replacement and put a drop of super glue on the edges to lock them in. Looks good on your Yellow rig.
Old Jul 1, 2024 | 04:40 AM
RobertDez's Avatar
Default Not WeatherTech...
These are some off brand from Amazon, figured I'd give them a try as they're only in the $60 range. So far so good. It beats the hell out of replacing the switches in the doors from water intrusion. As if the price on those switches wasn't High Enough, it requires a trip to the dealer to be programmed or your courtesy lights will not work. Not only will they not work properly, they will stay on all the time and kill your battery.
hummerz
Jun 24, 2022 07:48 AM
Bosshoss502
May 27, 2011 11:14 AM
machines
Mar 9, 2008 11:05 PM
solarflare
Jan 30, 2008 02:41 PM
