Passanger side AC actuator
Old Aug 14, 2019 | 08:40 PM
H2Miami's Avatar
Default Passanger side AC actuator
Hi everyone
Im replacing the passanger side actuator. The one that needs the dashboard removed .
Everything worked out well with removing the dash but once I get to actuator I cant see how to remove the 3 bolts holding it
I saw a video showing a 8 wrench which was grinded to make it slim to fit in and with lot of patience you may remove it . Then same pain to install
Is there a different way that gives you clearance enough where a ratchet can be used
Old Aug 15, 2019 | 07:32 AM
hummer_on_fumes's Avatar
Originally Posted by H2Miami
Hi everyone
You have 2 options really... one is to just reach your hand back there blindly and feel for the bolts, then unscrew them using a grinded down wrench (this is what I did). It seems daunting but it is really not that hard, it just takes some patience. Or, your other option is to cut the air vent, then repair it after.
Old Aug 15, 2019 | 07:47 AM
The actuator is behind this vent
This is the location as seen from the glove box
Remove this vent in order to make enough room to fit your hand behind the duct
Grinded down wrench
Old Aug 15, 2019 | 07:43 PM
H2Miami's Avatar
Thank you Hummer .
I just finished and it wasn't too bad .
I spent more time grinding the wrench than replacing the actuator
Really I dont understand why shops charge outrageous prices (700) for this
It took me 2 -3 hr total .
I would be able to donit in 1.5 if got to do it again
Also notice there is only 2 screws holding the actuator
Two on each side . Front of actuator there is a guide not a screw
Thank you again for the help
Old Aug 17, 2019 | 11:39 AM
oceanbrave's Avatar
Great posts !!
JimDrew
Jun 8, 2024 03:23 AM
humminchrome
Aug 14, 2022 01:03 AM
hummer_on_fumes
Nov 10, 2018 12:37 PM
hmer
Aug 2, 2018 06:45 AM
Damneck
Feb 28, 2012 10:06 AM
