AC vent actuator misery againnnnn
Old Aug 1, 2018 | 10:46 PM
hmer's Avatar
Default AC vent actuator misery againnnnn
last summer my passenger side was blowing hot air so i replaced the top hard to get actuator that fixed everything .... just today i started to get hot air again on the passenger side could it be that the bottom actuator went bad this time or it is always the top one that causes the hot air issue???????? i hate having to take this thing a part again ...
Old Aug 1, 2018 | 10:54 PM
hummer_on_fumes's Avatar
if I remember correctly there is a write up on here with a way to replace it without taking the dash apart. You could do the fuse trick and see if it starts blowing cold again on that side, then you'll know for sure it's the actuator
Old Aug 1, 2018 | 11:17 PM
hmer's Avatar
i had seen the write up before the one thats on the lower end you can replace easy the top one is the one thats a pain ....
Old Aug 2, 2018 | 06:45 AM
See if this thread helps:
https://www.hummerforums.com/forum/h...acement-39398/
humminchrome
Aug 14, 2022 01:03 AM
hummer_on_fumes
Nov 10, 2018 12:37 PM
Hooty-Hoo
Dec 3, 2015 06:28 PM
MidTNHummer
Jun 12, 2015 08:35 PM
Damneck
Feb 28, 2012 10:06 AM
