Blend Door Actuator Replacement
Old Feb 14, 2018 | 12:22 PM
H2Miami's Avatar
Default Blend Door Actuator Replacement
Hello ...
Im looking to replace the Actuator. Everywhere I looked it show a completely dismantle of the dash
But a member from this forum found an easy way . Could anyone give details how can it be done the easier way
Old Feb 14, 2018 | 12:51 PM
madmayo's Avatar
Dr drew had a really in depth post on here that i used when i did mine. I tried to get it made a "sticky" because of it being a common issue, but.... If i remember right there are three actuators. One on drivers side, one behind the center climate control and one behind the glove box.
Old Feb 14, 2018 | 12:55 PM
TeeStu's Avatar
Old Feb 14, 2018 | 02:25 PM
tharber's Avatar
Good info from TeeStu with the exception that on my 2005, the defrost actuator was to the right of the steering wheel, in other words to the center. It was a pain in the butt to get the upper bolt out and then align the 3 pins on the cam (will make sense once you get it apart).
Tim
Old Feb 14, 2018 | 08:55 PM
H2Miami's Avatar
Thats a great post . Will follow his route. For now the passenger side is blowing hot but I can said none of the 3 are in good condition.
Will end replacing all of them .
Old Feb 15, 2018 | 06:50 AM
If you have ever disconnected the AC control panel on the dash they might just need to be re-calibrated....
I ran into that on mine after I changed out the backlighting to red. Afterwards the passenger side blew about twice as hard as the drivers side. I did also have to replace the upper one on the passenger side - that is the most difficult one to do. I pulled the entire upper dash out to do it which was actually not as hard as I thought it would be.
There is a manual way to do it (last step below) as well as with a Tech2. Cannot hurt to try. This is from the GM eSI system...
Re-Calibrating Actuators
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
Important
Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
Preferred Method (w/ Scan Tool)
•Clear all DTCs.
•Place the ignition switch in the OFF position.
•Install the HVAC control module or actuator that needs replaced.
•Connect all previously disconnected components.
•Place the ignition switch in the RUN position.
•With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
•Verify that no DTCs have set as current DTCs.
Alternate Method (w/o Scan Tool)
•Clear all DTCs.
•Place the ignition switch to the OFF position.
•Remove the HVAC B fuse for a minimum of 10 seconds.
•Install the HVAC B fuse.
•Wait 40 seconds for the HVAC control module to self-calibrate.
Old Feb 16, 2018 | 11:00 AM
H2Miami's Avatar
MixmaSc ... I will try disconnecting the fuse . I havent do any work on the system but will give a try just in case .
Thanks for the info
Old Feb 22, 2018 | 07:12 AM
H2Miami's Avatar
I disconnected/ connected the battery for a while and so far looks like the problem went away. The vent is blowing cool air again. Thanks
Old Feb 23, 2018 | 06:19 PM
emericr's Avatar
looks like when i disconnected the battery to do my led conversion for headlights and fogs, one of the actuator went haywire. bought a replacement one on amazon for $25 and hope it will solve the issue. The one that went bust is the easy one by the passenger side (i was getting hot on passenger and cold on driver). this forum is a wealth of knowledge and I thank the guys that are here helping us.
Old Apr 6, 2018 | 07:15 PM
jongo8's Avatar
Important
•Clear all DTCs.
•Clear all DTCs.
I’m have the problem with the passenger side blowing 3 times harder than the drivers side. I disconnected the battery and still the same. What’s next to try?
JimDrew
Jun 8, 2024 03:23 AM
Lionel
132
Jan 9, 2018 12:32 AM
CHP
Mar 5, 2013 06:18 PM
ingydrummer
Feb 19, 2012 09:38 AM
Lionel
Feb 24, 2009 08:43 AM
