no crank or start situation
Old Aug 4, 2025 | 11:56 AM
you need to find the wiring to the ignition switch then the wiring to the china box and look at the wire colors. match them as you would your socks.red with yellow line to red with yellow line as an example. and reconnect them. you can use barrel connectors. if it was not a total hack job then maybe they used a harness adapter plug and you might just be able to plug right back into the ignition switch.
you just need to get your hands in there and get a visual of the situation.
Old Aug 4, 2025 | 01:44 PM
zapshd's Avatar
thanks everyone for the help, the small purple wire rotted off the starter lug, of course im still leary about getting stuck with this cheapie
alarm/pushbutton start. and should still have someone put it back to stock, what has to be done to get rid of the security key possible problems?
reprogram BCM? its a big issue with my 89c4 corvette, the wiskers inside the lock that read the resistor pill oxidize etc and leave you stranded.
not sure how ours work
Old Aug 4, 2025 | 02:29 PM
ECU tuning software can shut of VATS. (Vehicle Anti Theft System)
this is a free one https://universalpatcher.net/ based off of PCMhammer https://github.com/PcmHammer/PcmHamm...readme-ov-file
but EFI live and HP tuner will do it for a price.
Old Aug 4, 2025 | 08:26 PM
Mark R's Avatar
Wow....You guys are Amazing. This thread was very cool and shows why this HUMMER forum Rocks. Talent up the wazoo...
PGI Conch
Dec 31, 2025 03:04 PM
Robert May
Jan 29, 2025 11:07 AM
XLRH2
Sep 18, 2023 10:41 AM
Indskys
Oct 3, 2020 07:18 PM
Franky3030
Mar 5, 2010 08:31 AM
