no Crank, No Start
Old Feb 18, 2024 | 01:19 PM
jump145's Avatar
Sorry, I wasn't clear, the Hummer has been sitting since 2019, I assumed that since it had been started regularly that some fresh gas and oil and i'd be good to go.
If I had put oil in the cylinders and tried to break it free manually like you would any motor that's been sitting, I might have been able to save it.
It's too nice of a rig to part out though, so I'm looking at engine replacement options.
Old Feb 18, 2024 | 04:07 PM
Never really heard of an engine seizing from being started every couple of months unless maybe it was only for 10 seconds and was done like that for a few years in which case condensation could build up internally. I have a GMC with basically the same engine, just the 5.3 instead and it has been off the road for over 5 years now. Only gets started every couple of months but I do run it for at least 15 minutes each time to make sure any condensation gets burned off and give the battery a bit to charge back up. Have done other vehicles the same way in the past with no ill effects.
Old Feb 18, 2024 | 04:57 PM
jump145's Avatar
I'll try again here, H2 has been sitting since 2019, Senior owner claims it has been started regularly.
It obviously wasn't
I put gas, fresh oil, and a battery in it, and bang...crunch crunch crunch.
If it had been started periodically it wouldn't have seized, and if I'd known it hadn't been started, I would have had a different approach to getting it running.
Old Feb 18, 2024 | 06:36 PM
finall's Avatar
Lesson to be learned: Start the vehicle before you buy it. And don't naiively believe everything you are told..
I believe 50% of what I see, and 25% of what I hear and read. Helps a bit.
Don't believe anything I said. That will be a good start, LOL! (pardon the pun).
Lesson #2: If you buy a non-running vehicle, EXPECT the worst, and price accordingly. Anything less that the worst case scenario will be be a gift to you.
Old Feb 18, 2024 | 07:00 PM
BLK WLF's Avatar
Are going to have the engine fixed up for this H2?
atari800
Jan 31, 2016 07:30 PM
fayenet
Nov 20, 2015 05:25 PM
fayenet
Aug 4, 2015 03:44 PM
Ghost Rider
Aug 22, 2012 02:43 PM
GuestWho
Feb 6, 2012 07:23 AM
