New Member and needing to identify a part
Old Jul 31, 2020 | 03:30 PM
daisymay1212's Avatar
Default New Member and needing to identify a part
Hello all,
I am a new member, and also very green, so bear with me. Can anyone tell me what this part that is rusted through is called? Is it a heat shield? It is located behind the wheel well in the front.
I apologize in advance if this was not the correct forum to ask this question.
Thank you
Notice the two bolt connections are rusted through
Old Jul 31, 2020 | 04:15 PM
tharber's Avatar
Its the exhaust heat shield. Probably no big deal but if it's that rusty, check everything else especially the frame and brake lines.
Tim
Old Jul 31, 2020 | 04:20 PM
Tim
Thank you so much. I anticipate more rust when I get under there. Determined to save myself a bunch and try to do it myself. Heck, how hard can it be? (Famous last words)
Thanks again!
Old Jul 31, 2020 | 06:15 PM
Chrmer3's Avatar
Look at the bolts that hold the manifold to the engine (heads)- especially at the back toward the firewall. If you open the hood and look at them you may see some missing to the back- if so, you can buy the manifolds w/shields and correct the broken studs... its a job but needs to be done. I would bet you have at least one broken.....You can buy the Dorman manifolds fairly cheap - i want to say off top of my head under $75 each new on amazon....
Old Jul 31, 2020 | 08:03 PM
Thanks so much Chrmr. Will take a look at that too. There’s a whole lot of rust on the passenger side underneath, so I may be looking at a host of issues. Driver side doesn’t seem to be as bad.
B-HMMWV
Apr 1, 2015 07:16 PM
Hawaii H2
Mar 19, 2015 01:47 AM
TruckGuy616
Feb 11, 2013 03:20 PM
