Need stock distance from center of hub to fender
Old Oct 31, 2022 | 09:32 AM
legerwn's Avatar
Default Need stock distance from center of hub to fender
What is the stock distance between the center of the hub/axle to the fender on both front and back axles of the H2?
Neal
Old Nov 2, 2022 | 09:31 AM
legerwn's Avatar
I'm at 27.5" from center of hub to fender, hopping someone will post the stock measurement so we know what that is.
Going to put my H2 on the lift and check the Z & D trim height soon to get an idea of where I'm at compared to the stock trim height
Neal
Old Nov 3, 2022 | 07:08 AM
calif phil's Avatar
I have 25 1/2 " rear and 25 1/4" front.
Old Nov 3, 2022 | 08:47 AM
legerwn's Avatar
Thanks Calif Phil, appreciate the help
Neal
Old Nov 6, 2022 | 08:13 PM
Brunob00's Avatar
I just checked two stock 2008 Hummer H2s... looks like they need to be leveled... Front 1 = 24.5 (Center to top fender moulding edge)
Rear 1 = 25.5 (Center to top fender moulding edge)
Front 2 = 25.5 (Center to top fender moulding edge)Rear 2 = 25 (Center to top fender moulding edge)
Old Nov 7, 2022 | 05:51 PM
clsimmon's Avatar
Assuming everything is factory, the best way to check body height is to confirm ground clearance on page 6 of the attached.
Old Nov 12, 2022 | 10:55 AM
legerwn's Avatar
appreciate the info Brunob00 and clsimmon
Neal
Wesley
Jan 30, 2019 10:48 AM
NFS
Mar 22, 2018 12:43 PM
H3Coyote
May 2, 2014 01:20 PM
LoJac963
May 1, 2014 09:25 AM
Stick
Dec 27, 2013 09:52 AM
