Lug nut torque settings?
Old Nov 8, 2021 | 04:46 PM
oceanbrave's Avatar
Default Lug nut torque settings?
For standard alloy, i.e.
From the GM Service Manual I have:-
Ordinarily I'd stick with the manual, however I've seen figures of 90-100 ft.lbs but I've just been questioned on this.
Please could someone confirm what the torque settings should be for a standard alloy rim?
Thanks guys...
Old Nov 8, 2021 | 05:07 PM
Old Nov 8, 2021 | 05:17 PM
oceanbrave's Avatar
Thanks hummerz
Indeed I've seen that same list (sparkyexpress?) anyway I trust your judgement, 140 it is
Old Nov 8, 2021 | 05:21 PM
finall's Avatar
140 ft-lb is spec'd in the manual.
In practice, once that corrosion sets in, that 140 turns into a seized 200 ft-lb in the blink of an eye.
And wheel locks get rounded-off and ruined.
Torquing to 110 lb is plenty in my experience. Never seen one loosen at that spec.
When I torque to 140 lb, I crack the nuts yearly to avoid seizing.
My brand new C8 Vette calls for 140 ft-lb also.
Nuts!
Old Nov 8, 2021 | 05:31 PM
All the shops have to torque to mfg spec.!!!, many include a 2 pass on ALL wheels, or possibly get sued. DIY, torque you decide, is on you!
Old Nov 8, 2021 | 05:58 PM
oceanbrave's Avatar
finall
Thanks, good to know other experiences.
In the past I had a couple of lug-nuts work loose, perhaps I missed them, but I'm very careful so it's a mystery. Now I inspect the lug-nuts, threads and rim, then torque-up in the criss-cross pattern, and then double-check in a different order.
140 is an effort for me, as is lifting the wheels, must be an age thing....
Old Nov 8, 2021 | 06:06 PM
finall's Avatar
I just drive .
When I hear a clunking sound inside my center caps, I figure a lug nut is loose. No worry, keep driving.
Once the clunking sound increases, and I hear what surely must now be 2 lug nuts tumbling around like marbles on a treadmill, only then do I pry that nasty center cap off the wheel and put them back.
You have 8 per wheel. You only need 4 to keep the wheel on. The others are just for show to tell people how Macho your truck is. And it is not like you are ever going offroad in your parking lot princess to need the 5th lug. Leave that to the H1.
JK
Old Nov 9, 2021 | 08:08 AM
calif phil's Avatar
I just did mine at 140lbs, I went with 100lbs on the spare to the rack.
Finall Congrats on the C8, I bet it's fantastic.
Old Nov 9, 2021 | 05:51 PM
Nuts!
BS! Only torque to spec! My 3 calls for 100, yet I take them to 110-120, and they always take less torque to remove. Loose lug nuts=lose wheel!
For your eyes ONLY:
oceanbrave
Apr 11, 2018 03:11 PM
wildcardgirl
Feb 13, 2014 08:31 PM
Kdog
Dec 14, 2011 04:48 AM
PhilB
Mar 22, 2010 11:08 AM
USMCSKI
Nov 30, 2009 05:45 PM
