Lower control arm ball joint replacement
Old Jul 2, 2021 | 08:48 PM
H2-SUT's Avatar
Default Lower control arm ball joint replacement
I currently am going thru my 08 and replacing the upper control with a new premium Moog arm. The boot on the original was shot and considering I have 97k on the truck I thought I would just replace the whole assembly.
Here comes the question, unfortunately, moog does not make a premium replacement that is better then the original. Has anyone on the forum done a ball joint replacement on the vehicle, if so how bad was it?
Actually the upper and lower ball joints were not bad, its just that the upper had a torn boot and no zerc and I did not just want to replace the boot considering I need to separate the joint anyway. Suggestions?
Old Jul 3, 2021 | 12:20 PM
tharber's Avatar
Look for Moog Sever duty or Kryptonite ball joints. The lowers are really not that prone to failure like the uppers. Don't forget to buy new castor/camber plates and bolts. I probably have a set that I will send you for free if you cover the shipping. I've sold my H2.
Tim
skicranmore
Sep 24, 2014 08:36 AM
BERULAKIDE
Apr 20, 2014 05:09 PM
Mcpousnret
Jan 21, 2014 12:21 PM
DanRay83
Jun 26, 2012 09:04 AM
