Looking for help
Old Aug 21, 2019 | 07:42 PM
Jeff Wagner's Avatar
Default Looking for help
I have a 2005 H2T I bought it new have not had an issue until today. I pulled it into the garage and as I put it in park he shifter felt light going into park so I tried to go back in drive and the shifter locked I turned the key to off now the engine will not turn over and the shifter is still locked. I had this happen when the battery was dead but have a good battery lights works windows move but something is going on. I disconnected the battery to see if I could get something to reset but nothing.
any ideas?????
Jeff Wagner
2005 H2T
Old Aug 21, 2019 | 09:57 PM
check your shift cable at the transmission. maybe it separated from the shift fork since you say the shifter "feels light"
Old Aug 22, 2019 | 02:06 PM
Or the wiring to the shifter lock solenoid (also under the shifter). Those have been known to get worn through and cause the solenoid to not longer retract when you press the brake to shift out of part.
Old Aug 23, 2019 | 11:00 AM
Default Transmission issue
The plastic bushing that connects the shifter cable to the linkage arm at the transmission fatigued and broke
i went the GM dealer they only sell the complete cable $80 and special order
Pep Boys had the bushing for $10 looks like a common issue for GM
thanks for all all the feed back
Jeff Wagner
2005 SUT
Old Aug 23, 2019 | 12:29 PM
Excellent - totally forgot about that stupid bushing on these. Had to replace that on my GMC truck several years ago.
Old Aug 23, 2019 | 12:34 PM
that's why i mentioned to check there first. those bushings crumble.
Old Aug 23, 2019 | 01:57 PM
Jtansek 03 H2's Avatar
Agreed. I had the same problem. The bushing is available on Amazon.com. Doorman part# 14057
jman1335
May 3, 2020 09:22 PM
Mogman8
Sep 19, 2017 04:59 PM
BLDNHNR
Jun 28, 2016 10:45 AM
dougie
May 20, 2016 01:40 PM
sm71
Aug 25, 2011 05:55 PM
