Lifter noise, exhaust leak, flex plate, or something worse? 2008
Here is a video that clearly demonstrates the sound(inside the cab while driving) It is definitely more pronounced when moving.
Btw, the set is all over ebay cheap! Look for these parts: Exhaust Manifold Bolt Repair Kit For Driver's Front /Rear Passenger Front/Rear
The clamp for the rear driver side bolt works great and is a permanent fix. Bit of a pain to install as there is a threaded hole on the back side of the block that you have to thread a bolt into by feel as you cannot see it. Once the clamp is bolted on then you can simply tighten another bolt that will push the manifold back against the block. Easiest is to remove the front wheel and wheel house liner and get at it that way.
Justinh
Feb 20, 2014 07:23 PM
