LED Fog/DRL Daytime Running Lamps
Old Feb 18, 2022 | 01:40 PM
TeeStu's Avatar
Default LED Fog/DRL Daytime Running Lamps
Finally, looks like a Direct Fit Plug N Play LED Fog/DRL Daytime Running Lamp Assembly for the H2s. I haven't seen the kit yet but looks like the only wiring (besides OEM Plugs) would be for the Halos. Anybody got these yet ??
Amazon Amazon
Old Feb 18, 2022 | 02:38 PM
Oh wow! LOL - they obviously came here on these forums and took my exact idea and even stole one of my pictures!!! I am in some respects, flattered. For what its worth. I do think it is a good value if the brackets work. That was the longest part was figuring out some way to modify them so that I could mount them. They are also about the largest light I was able to find that would fit the pocket better as most aftermarket lights are only 4 inch which leaves a large gap around the edge. They also do work very well. The DRL rings are very bright though, at night you will get flashed of those are on. The driving light function is pretty darn good. They are no nearly as good as say, Diode Dynamics SS3 Pro's but they are not terrible by any means either.
So these are aftermarket lights for a Toyota Tundra. They simply went with my idea for using these and made their own bracket for them. I'm betting you will still need to correct plugs for the DRLs unless you want to cut the stock wires. In my original thread below I also detail how you can use a latching relay from Amazon along with a factory rear wiper/fog light button from a Tahoe/Yukon/Suburban to control the fog lights....
So here is my original thread for these from back in 2017. https://www.hummerforums.com/forum/h...-lights-39090/
And this post of mine from 2018 has the exact picture they stole and put in their Amazon listing. https://www.hummerforums.com/forum/h...45&postcount=3
In this pic you can see the same connection box and where I mounted it....
Attached Thumbnails LED Fog/DRL Daytime Running Lamps-img_20190314_151244535.jpg
Old Feb 18, 2022 | 03:11 PM
TeeStu's Avatar
I would definitely take that as a compliment that they copied you.............
hummer_on_fumes
Aug 7, 2020 07:26 AM
accely
Nov 26, 2019 10:07 AM
parrip
Nov 1, 2015 06:56 PM
bosoxdew
Sep 8, 2012 07:43 AM
RyanCodyH3
Apr 8, 2008 01:31 PM
