HVAC blower
Old Dec 4, 2017 | 06:39 AM
OWRLTD's Avatar
Default HVAC blower
Has anyone else been annoyed with the noise coming from that blower. I've cleaned the debris from it. Then replaced it with a Delphi unit, and still.
Any ideas? Premium replacement? Insulating?
Old Dec 16, 2020 | 11:14 PM
CAPT's Avatar
Default Hvac blower
I have same annoying problem on my 08 H2 — cleaned out the debris and there’s still a high-pitched, repetitive whirling noise ... the noise slows and goes away when I turn off the fan.
*** Presume it’s the HVAC Blower motor — p/n: 89109320.
Is there anything else it could be before I invest in a replacement HVAC Motor?
Thanks for any helpful info! Respectfully,
CAPT JC
Old Dec 18, 2020 | 03:30 AM
oceanbrave's Avatar
It's possible to run the fan on the bench, ideally using a variable voltage power supply, but a car battery would do. As I recall it takes around 8amps at 12V.
However, be careful to fix the fan down as it has a lot of angular momentum
You'd then know if the noise is coming from the fan itself.
Old Dec 18, 2020 | 08:52 PM
CAPT's Avatar
Oceanbrave — Many thanks for the very quick response. I appreciate the technical approach; given the direct correlation btwn fan noise and climate pushbutton ‘on/off’, confident that the blower fan is the culprit. Plus — I don’t have access to a bench to do the forensics (need you as my neighbor!).
ps ... I found a knowledgeable HUMMER tech in the JAX area who confirmed my suspicion ... his advice: don’t replace it with a cheap blower motor ... buy GM / OEM part.
Again, thanks and drive safely! Best, CAPT JC
humm309
Jul 1, 2020 10:53 PM
Mark68
Sep 16, 2019 04:33 AM
EVILKING
Feb 12, 2015 05:49 AM
dan385
Feb 25, 2014 05:27 PM
Hummermom
May 15, 2012 07:15 PM
