HVAC blower
Has anyone else been annoyed with the noise coming from that blower. I've cleaned the debris from it. Then replaced it with a Delphi unit, and still.
Any ideas? Premium replacement? Insulating?
*** Presume it’s the HVAC Blower motor — p/n: 89109320.
Is there anything else it could be before I invest in a replacement HVAC Motor?
Thanks for any helpful info! Respectfully,
CAPT JC
It's possible to run the fan on the bench, ideally using a variable voltage power supply, but a car battery would do. As I recall it takes around 8amps at 12V.
However, be careful to fix the fan down as it has a lot of angular momentum
You'd then know if the noise is coming from the fan itself.
Oceanbrave — Many thanks for the very quick response. I appreciate the technical approach; given the direct correlation btwn fan noise and climate pushbutton ‘on/off’, confident that the blower fan is the culprit. Plus — I don’t have access to a bench to do the forensics (need you as my neighbor!).
ps ... I found a knowledgeable HUMMER tech in the JAX area who confirmed my suspicion ... his advice: don’t replace it with a cheap blower motor ... buy GM / OEM part.
Again, thanks and drive safely! Best, CAPT JC
EVILKING
Feb 12, 2015 05:49 AM
dan385
Feb 25, 2014 05:27 PM
