Hub replacement question
Quick question for you gents. Driving home from emissions last week I started hearing an intermittent scraping noise every time the driver side wheel turned. Long story short, that hub is bad. I already have a new Timken hub on order with the 36mm socket.
My question is, would you replace both hubs at the same time or just one at a time? Part of me just wants to do both but I'm torn. I actually haven't checked the passenger side yet since its against the wall-I have to fix the driver side and pull her out of the garage first.
It has also been mentioned to replace the CVs as well since everything is apart but if they aren't bad why replace?
I replaced my hubs about 5K apart, both before they were really bad. Takes me about 1.5 hours each side. I just wanted to be able to count on them and not have to worry about when they would fail.
This past fall when I did the whole front end, because I wanted it all to be good to go, I did the half shafts as well.
All pretty simple, I'm sure you can do it.
Good luck!
Good luck!
Do you guys replace the O-ring as well? I've heard to replace or don't worry if it's not worn but I feel like for $5 each why not just replace them? I ordered new front 5100 Bilsteins so I'm putting the hub replacement on hold since I might do new A-arms as well.
a local shop did my driver side wheel hub replacement and i was there while they did the process and i saw the mechanic try to fit the old o ring but then ended up throwing it out, i dont think the hub assembly came with a new o ring and i was wondering if u knew what the purpose of the o ring is. the hub/wheel bearing is a sealed unit so i am confused. the repair was just done a couple days ago and i read that people say to replace the o ring or something. is this a case where i have to take it apart and instlal a new o ring or is it fine without it?
thx
sorry to bump an old thread but i wanted to ask about the o ring
thx
thx
interesting question as I just changed my passenger side hub this evening....
during removal.....I did NOT see an o-ring of any kind.
i looked over all the box/new hub and same....did not see an o-ring.
I will do the driver’s side tomorrow. Don’t expect to see an o-ring.
Mines a 2005
Just to cause some more confusion/confirmation.....summer of 2018, i replaced the driver’s side hub on my 2012 Silverado. Same situation.....NO o-ring. Been driving for 2 yrs now and now issues.
oh wow, heres a pic does this ring a bell?
im not very techy but i believe it sits in the steering knuckle where the hub meets when you install it.
heres a link and a pic
https://dmaxstore.com/products/?rout...spindle+o+ring
https://www.rockauto.com/en/parts/ac...b+o-ring,12808
maybe keep an eye out for this?
thx
thx
