How to tell if Cluster is accurate
Old Apr 29, 2023 | 06:55 PM
jhall's Avatar
Default How to tell if Cluster is accurate
Is there a way to check the gages to see if what they are reading is accurate ?.....like it says 40 psi oil pressure....and water temp is 210....is there a way to check and see if the needles on the gages are correct?....or is there a way to make sure they are set at zero?.....the reason i ask is i recently sent my cluster back to get a "rebuild" ....prindl was out and several lights ...got those replaced as well as all the stepper motors.....seems like when i got it back the oil pressure needle reads a little lower than it did before i sent it off as well as the water temp....
Old Apr 29, 2023 | 08:29 PM
oceanbrave's Avatar
The gauges are positioned electronically to reflect actual sensor values, their readings and range of movement can be tested and checked using a Tech2 diagnostic tool.
Perhaps the gauges were inaccurate before and are now accurate, or their needles misaligned during rebuild, for example
LoJac963
Jun 25, 2013 07:12 PM
jcromer09
Mar 2, 2011 04:06 PM
Mighty455
Jan 5, 2011 04:25 PM
therobesons
Nov 24, 2009 06:42 PM
gregaac
Jan 17, 2009 10:49 PM
