How to remove H2 door lights?
Old Sep 10, 2013 | 09:26 AM
DanH3's Avatar
Default How to remove H2 door lights?
Hi all.
I just traded in my 06 H3 for a 04 H2 and I'm trying to give it a few upgrades. One of the upgrades is changing out all the interior lights with LEDs. I have changed out all of them except the courtesy lights in the doors. Does anyone know how to take the light fixture out of the door panel? I tried poping one out last night but I ended up cracking the lens. I did a search on the forums here and on google but I couldn't find the answer. Any guidance would be appreciated.
Regards,
Old Sep 10, 2013 | 02:26 PM
LoJac963's Avatar
If I remember correctly you need to pry towards the door edge and pop that end out. The other end which would point towards the front slides into the panel so once the edge end is out you slide the whole assembly rearward.
I need to replace one of mine from cracking also.
Old Sep 10, 2013 | 03:26 PM
DanH3's Avatar
thanks LoJac. I'll give that a shot. That was the end of the unit I started at but the red piece of the lens cracked off. I'll continue to try and pry off the door edge side some more. The lens is already broken, so I can't do too much more damage. lol
Old Sep 10, 2013 | 05:04 PM
Nate2106's Avatar
Yup, LoJac is right. I cracked the same thing so I just took the whole panel off. Depending on the size of your LED's you might have to drill out the back where the light is inserted. Mine we just a 1/8th small so i just SLOWLY took a drill to it.
Old Sep 10, 2013 | 07:48 PM
LoJac963's Avatar
Yup, I used a round file to make my openings slightly larger for the LED's I put in them.
Glad you got it out though.
When I did my full interior in LED's no one had any info on removal of any pieces. I basically went as gentle as I could with some of the parts but some lenses especially the lower courtesy lights at the bottom of the pillars you really have to pry on. I thought for sure I'd break things left and right but they eventually pop free.
Good luck with the LED swap!
Old Dec 4, 2021 | 08:20 PM
DaveP28's Avatar
Default Door lights
Well. I just wanted to make a post about the options out there now. My 2006 door lights are pretty dim and yellowish.
Yes, I did try the LED replacement blub when I had to change a window regulator.
But the better option is the full LED fixture... I think I paid under $40 for a set of 4 and they are kind of blinding.
I have no financial interest in the sales of anything here... just what I hope is some good advice.
Fitting new bulbs and having to grind open the hole to fit the new bulb is a waste of time.
Here are pics of all 3 options
Factory Bulb,
LED replacement bulb.
LED replacement fixture
Best!
Old Dec 6, 2021 | 01:16 PM
eviltwin's Avatar
Glad someone else brought it up. The new LED replacement courtesy lights are blinding. Even with a limo tint it looks like full daylight inside the truck at night. I may disconnect the fronts and cut the light in half
Old Dec 6, 2021 | 11:02 PM
Sam!'s Avatar
How do these open up for replacement?
Pillar post base lights
Old Feb 25, 2025 | 11:51 AM
H2Singh's Avatar
Default Part number for Pillar post base lights
Hi Sam!
Do you have the part number for this light? I bought an H2 that does not have a cover on it and I can't find the correct part number or name for this light/lamp.
hummer_on_fumes
Feb 2, 2021 01:57 PM
clsimmon
Oct 5, 2017 07:08 PM
slider28
Sep 27, 2014 05:11 AM
LoJac963
Sep 7, 2011 07:50 PM
quadblaster240
Aug 28, 2009 01:37 PM
