How to recalibrate a bose amplifier Tech2 Instructions
Old Jun 22, 2020 | 07:56 PM
  #21
have you checked if the can 2 passthrough is enabled on the radio with a tech 2
Bronx, this is a plug and play, just like connecting a turntable/8track/cassette deck etc... to your home receiver.
Old Jun 22, 2020 | 08:01 PM
  #22
Originally Posted by hmer
yeah the usual Am . Fm and also the xm1 and xm2 . On xm1 i can see channel 0 blank where the radio ID should display this goes back and forward from 0 to 9 and xm2 channel 184 only but no preview audio and there’s Some text that you can see on this picture. I called Xm support thinking they will be able to tell me exactly what this text may mean but the 2 people i talked to did not know anything .
https://ibb.co/QCLWwRm
If this is the first time the unit is connected and receiving satellite signal, the display may read“UPDATING” until the SIR-GM1 channel update is completed. This is where the latest channel line up is updated on the SIRIUS Receiver. NOTE: Don’t push any buttons or perform any operations until updating has been completed.Once updated and the SIRIUS channels are received, you will be tuned to SIRIUS Satellite Radio’s Preview Channel (Channel 184). You should be able to hear the SIRIUS Preview channel’s Audio.
Old Jun 22, 2020 | 08:08 PM
  #23
hmer's Avatar
no what are the steps to check for that ?
Old Jun 22, 2020 | 08:10 PM
  #24
hmer's Avatar
i waited 37 minutes exactly inside the truck and nothing was coming in .
Old Jun 22, 2020 | 08:23 PM
  #25
Just looked at the pic you posted.
disconnect power(pull fuses) to the radio and xm module, reboot.
Btw, what constant power source/ground did you use for the xm module?
Old Jun 22, 2020 | 08:45 PM
  #26
Radio, amp, xm module should be hot at all times, and chassis grounded.
Old Jun 22, 2020 | 09:41 PM
  #27
it mentions many GM tsb's related to XM some for programming in the gm dealer software herehttps://cardiagn.com/gm-service-manual-iso/ you really need that software if you use a tech 2 i have installed it on XP, windows 7 and windows 10. but for windows 10 you have to give the software administrative privileges if not the virtual machine in the program will not run
i did a search for 2003 2010 -2003 N body truck and the query was XM
Old Jun 22, 2020 | 11:20 PM
  #28
hmer's Avatar
ok thanks man .
Old Jun 23, 2020 | 09:39 AM
  #29
Set your radio to channel 0 tap display to get radio id. Try refresh radio
Old Jun 23, 2020 | 08:14 PM
  #30
hmer's Avatar
already tryed all the things you can think off im gona give a rest for now . I do have 2 factory Xm modules one from a 2003 escalade and another one from a 06 h2 both not vin locked anymore. After doing some diging on my shop repair manual iM trying to figure if i can make my own harness.
