How to recalibrate a bose amplifier Tech2 Instructions
Old Jun 22, 2020 | 04:13 PM
let me know if you need better pictures of it
Old Jun 22, 2020 | 05:17 PM
hmer's Avatar
that is the exact same one .
Old Jun 22, 2020 | 05:20 PM
Originally Posted by hmer
after one more try and reading the installation manual i had no luck at all . for some reason i think maybe the harness has the class 2 data cable in the wrong place ? acording to everything i had read about XM wiring on the H2 the OEM receiver has the class 2 data cable going from the receiver itself to splicepack 205 to communicate with the rest of the truck . this harness for the aftermarket module goes from the module to the radio . the tech2 looks like no matter what i do wont see the module at all and acording to what i had read this module does suport class 2 data comm . im about to give up on this .
again, you need the T-harness, remove connector from radio, connect it to the T-harness, and connect the other connector from the T-harness to the radio. Radio takes control from there.
Old Jun 22, 2020 | 05:29 PM
Don't forget the sat antenna. You should receive preview if connected properly. I just checked mine and I get xm1 & xm2 and current offer of 5bucks a month.
Old Jun 22, 2020 | 05:30 PM
hmer's Avatar
exactly the way i have it done .
Old Jun 22, 2020 | 06:01 PM
along with the power harness connected(hot at all times) and properly grounded.
Old Jun 22, 2020 | 06:56 PM
hmer's Avatar
i dont have the part that goes to the battery with a noise reduction thing I just taped in to constant power from somewhere else and the antenna is a oem GM equinox Xm antenna that should work . i wonder if that’s my problem.
Old Jun 22, 2020 | 07:20 PM
what do you get when you cycle the band button? fm1 fm2 am xm1 xm2 etc...
Old Jun 22, 2020 | 07:35 PM
have you checked if the can 2 passthrough is enabled on the radio with a tech 2
Old Jun 22, 2020 | 07:46 PM
hmer's Avatar
yeah the usual Am . Fm and also the xm1 and xm2 . On xm1 i can see channel 0 blank where the radio ID should display this goes back and forward from 0 to 9 and xm2 channel 184 only but no preview audio and there’s Some text that you can see on this picture. I called Xm support thinking they will be able to tell me exactly what this text may mean but the 2 people i talked to did not know anything .
https://ibb.co/QCLWwRm
