How to recalibrate a bose amplifier Tech2 Instructions
Old Jun 19, 2020 | 08:39 PM
hmer's Avatar
Default How to recalibrate a bose amplifier Tech2 Instructions
Took the time to put together this video and wanted to shared here hope it may help someone in the future.
Old Jun 20, 2020 | 05:22 AM
oceanbrave's Avatar
Hats off to you well done - that's a great video!
Old Jun 20, 2020 | 08:23 AM
calif phil's Avatar
One of your best videos.
Old Jun 21, 2020 | 03:41 AM
hmer's Avatar
Thanks for watching guys. Honestly after I installed my radio (nav radio)And rewire the amp harness a while ago i was going crazy from not being able to fix the no sound issue . Thats what got me to finaly buy the tech2 .
Old Jun 21, 2020 | 01:30 PM
have you tried activating the XM module with the tech 2?
Old Jun 21, 2020 | 04:52 PM
hmer's Avatar
you mean the aftermarket one in this video ? You know what no not really. Im using the harness that came with it and when I turned on all i see is the 2 Xm channel but the xm info is grayed out xm1 only shows channel 0 but don’t display the radio id and xm2 shows channel 184 but nothing comes up on that channel and for this unit channel 184 is the preview channel. Since my h2 did not have xm should active anything with the tech 2 ???. I know if you look on this video the part where the tech2 trys to look for the digital radio receiver does not see anything. Let me know what you know.
Old Jun 21, 2020 | 10:36 PM
what it looked like to me in the video was the radio was off when you accessed the amp. if the radio is off the tech 2 will state it has no communication with the radio like in your video.
you can read the install procedure here http://www.siriusretail.com/pdf/manu...al05162006.pdf the module might still have the previous vehicles vin number encoded
Old Jun 22, 2020 | 12:59 AM
hmer's Avatar
thanks for letting me know ill let you know how it went .
Old Jun 22, 2020 | 03:27 PM
hmer's Avatar
after one more try and reading the installation manual i had no luck at all . for some reason i think maybe the harness has the class 2 data cable in the wrong place ? acording to everything i had read about XM wiring on the H2 the OEM receiver has the class 2 data cable going from the receiver itself to splicepack 205 to communicate with the rest of the truck . this harness for the aftermarket module goes from the module to the radio . the tech2 looks like no matter what i do wont see the module at all and acording to what i had read this module does suport class 2 data comm . im about to give up on this .
Old Jun 22, 2020 | 04:00 PM
the one that was in my truck looks like this
the gray/light gray and black/blue plugs where connected to the radio and the radio harness the small white plug with the yellow and black wire where connected black to ground and the yellow to power.
