Hummer H2For those who like a little more gleam to their Hummer, the H2 offers a similar rugged look as the H1, but as a lower cost, and with more added features, making it almost a massive luxury SUV.
Literally pulled into the driveway with the engine overheating, thank goodness I didn't get stranded.
Popped the hood and see that the right coolant line out of the firewall is disconnected. It's completley snapped off what appears to be the the fitting still inside. Plastic???
What type of repair is this? What's connecting this line?
Yeah those plastic connectors generally are pretty weak. Usually only break when you try to remove them. Dorman, NAPA, etc make a replacement one. Since you will have it off I'd go ahead and use the opportunity to flush the heater core and replace both of the connectors. They can be a stubborn pain in the butt to remove too...
I just stick a garden hose on the nipples that are sticking out once you have both hoses/connectors off. Do not use extreme pressure but flush it good both directions. You would be surprised how much gunk comes out and how much better the heat will work later on. lol
