HEAT / AC Issue
Thanks Everyone! I received my Vertronix Tech II- It works great! I was able to re-calibrate the actuators and now the driver's side is working correctly, The scanner tells me that the passenger side actuator is stuck so I guess I will be taking the dash apart.
I'm pretty sure he got this one.... Vetronix GM Tech2 with Case for GM/SAAB/OPEL/SUZUKI/ISUZU with Candi Module Tech2 That is the same one I got a couple of years ago.
Note - The TIS2000 and USB key is only needed if you want to update the software on some of the computer modules (which can fix minor issues with the updates) but you will need an older PC with Windows XP (can also work on Windows 7 though) and a serial port to use the TIS2000 software.
Hi Yes, This is the TECH II that I purchased. I have fully tested it with all systems now and it works great. It told me that I had to replace both of my climate blend door actuators. I was able to tear the dash apart and replace them in 2 hours. Now my AC works again!!!
pvmh3
09-07-2011 08:30 AM
