AC door actuator
Old May 23, 2018 | 06:20 PM
H2Miami's Avatar
Default AC door actuator
Replace the door actuator for a new one but is not working properly either . Now is even worse , the air coming from the 2 passenger size is burning hot .
After replace it I disconnected the fuse for about 1 min . connected back , turn engine , let it run for 1 min 74 on display ( hot air on passenger) turn off engine , wait 15 sec . turn on engine . play with controls , even set both sides on 90 ... nothing change in any setting ...
Im I missing something ...
Thank you . will appreciate help . temp in FL is 90 now and going up
Old May 23, 2018 | 07:57 PM
H2Miami's Avatar
tried disconnecting the battery but didnt work either . for what I noticed , at start it blows cold for couple sec then switch to hot on passenger
Old May 23, 2018 | 09:16 PM
H2Miami's Avatar
Fixed ... Again disconnected the battery ... This time only the Negative , I leave it 30 min
Connected back ... Turn ignition .. not engine . leave ignition on for 30 min , turn off ignition for 10 sec . Turn engine on and BINGO , it start working
Btw if you made the mistake and test the actuator out of the place it will turn all the way Clockwise . will not fit back but you can fix it to the middle position again .. Here is a video showing how to reset the actuator
Old Sep 20, 2018 | 01:20 AM
twynbyz's Avatar
I know this is an old thread but I've tried exactly what you've done. I've replaced the same actuator for the passenger side, unplugged the battery even overnight. I then let the car run 30 mins and even left it in accessory mode for 30 mins and still no dice. Do you have any other suggestions? I'm literally going crazy over this....
Thanks in advance for any advice you could provide!
humminchrome
Aug 14, 2022 01:03 AM
asorber
16
Jun 11, 2019 10:36 PM
H2Miami
May 10, 2019 10:02 AM
Kdk
Apr 20, 2017 07:46 AM
ThatGuyRooT
Apr 11, 2016 05:52 PM
