h2 steering issue
Old Dec 1, 2022 | 08:47 AM
wheelieman's Avatar
i mean i HAVE the stock wheels on it.
Old Dec 1, 2022 | 10:49 AM
legerwn's Avatar
does it now center as it should after re-adjusting/loosening the sector lash bolt
Neal.
Old Dec 1, 2022 | 01:00 PM
Binding/sticking steering damper? No idea, just a wild guess.....
Old Dec 1, 2022 | 01:13 PM
finall's Avatar
Good guess MixManSc! That is just a horizontal shock absorber. Could be if rusted up badly Or bent shaft on it.
op should remove it and test steering.
Old Dec 2, 2022 | 08:53 AM
wheelieman's Avatar
hello, today i toke off the demper, but no result. damn it. not even a bit lighter then before.....
it drives good but the steering is a bit rough/heavy? doesnt matter if i losen the bolt on the steering house or tightning it, thats only resulting in more or less slack in the steering wheel.
can i put a video here? it looks simple. when you drive in a straight line en just steer a bit to the right or left , the steering is sticking a bit to that position, its annoying .
maybe the steering fluid is not the good one? i m thinking out loud. steering case bad? too rough/sticky?
Old Dec 2, 2022 | 09:14 AM
wheelieman's Avatar
i found a guy with same problem: idk if im allowed to link it here?
Old Dec 2, 2022 | 12:06 PM
wheelieman's Avatar
i typed in youtube: steering wont turn to center and more ppl have this problem
Old Dec 2, 2022 | 12:57 PM
finall's Avatar
PS fluid should be changed out at least every 4 years. It gets real dirty in the H2.
if it is dirty, then you need to flush out 2x in a row.
cheapest prevention.
Old Dec 2, 2022 | 02:01 PM
what pressures are you running on your tires?
Old Dec 3, 2022 | 02:43 AM
wheelieman's Avatar
today i gonna flush/replace the steering fluid. last thing i can do.
