H2 Fuel Tank / Fuel Pump
Old Jan 29, 2019 | 12:46 AM
Savage00's Avatar
Originally Posted by MixManSC
My understanding is only 2003 models have an externally accessible fuel filter. All later models just have a screen as part of the fuel pump itself.
Not sure about other years. The original fuel pump has a stainer on the bottom external of the pump. The new pump has the strainer built into the pump as described in the product description. Not sure if that's what your talking about?
Old Jan 29, 2019 | 06:46 AM
Not exactly but yes. My understanding is on 2004 and newer models that strainer on the pump is the only fuel filter and is not really replaceable. On the 2003 models there is an external fuel filter attached to the crossmember just at the front of the tank which is fairly easy to replace. Later models do not have that replaceable one.
Old Jan 29, 2019 | 07:52 AM
calif phil's Avatar
Great pictures, My '03 had the replaceable fuel filter and my 2006 does not. I liked having the replaceable filter and would change it every 30,000 miles with a WIX filter.
Old Jan 30, 2019 | 12:39 PM
Savage00's Avatar
Yes, as notated in the second pics. On the 2003 The fuel filter is mounted on the front of the fuel tank just behind the center cross member. It is a little awkward to get to but can be done. You have to work blindly (by feel) to get the fuel line connections on and off. Just make sure your head is not directly under the filter or you’ll get a face full of residual fuel coming out of the lines!
Old Jan 30, 2019 | 01:26 PM
Lol - I did just that and got gas on me anyways when I changed mine.
Old Feb 1, 2019 | 11:52 AM
iwillnc's Avatar
Great write up, unfortunately I had my Fuel pump go out about a year ago now during a snow storm 3 hours from home, great timing. Normally I do all work on my vehicle but for the price of getting it towed 3 hours it was cheaper to have someone else do the work. Believe it cost me $560 with parts and labor. FYI GM wanted $1,100. I have an 03 as well and I've had a new external filter sitting in my garage for at least 4 years now that needs to go on.
Old Apr 23, 2019 | 10:53 AM
Paula Reeves's Avatar
Default Gas tank
Anyone know who replaces the fuel lines on top of 05 h2 hummer. The nylon lines that are wraped to tank...
Old Apr 23, 2019 | 09:05 PM
H2Miami's Avatar
Is going to be a fun weekend .
The pump on my H2 quit working. Well another thing to replace. After all the repairs I almost have a 2019 truck
Could you post the procedure to remove the tank . Did you remove the hoses with tank hanging or there is enough slack to pull it down then remove it
Also would I be able to siphon the gas . Is there anything blocking a hose going thru the gas door
Anything else to look once tank is down . Hoses ? Lines ? . . Cleaning Etc
Thanks . Those pics are great
Old Dec 4, 2019 | 12:00 AM
United Timber's Avatar
Originally Posted by mulepic
On my 08, #7 in your picture above developed a small leak. Only noticeable when the tank was filled up. Luckily I was able to reach up there and use a mirror to put some sealant around it. Haven't had a problem since. Thanks for sharing this.
My 2008 H2 is seeping gas around #8 in that diagram, the base of the fill neck on the rear end of the fuel tank where the fill hose clamps to. What kind of sealant did you use?
Old Dec 4, 2019 | 04:52 AM
mulepic's Avatar
Not a good one b/c I just started smelling gas again. Your issue sounds like it needs a new hose and clamp.
