H2 2006 - sunroof seal is end of life
Old Jun 17, 2024 | 03:54 AM
leto49's Avatar
Default H2 2006 - sunroof seal is end of life
Hello,
I noticed the seal around my sunroof started to die, with a hole on the top side of it.
I tried to find this part but without any success so far. It seems to be discontinued at GM, and I'm a bit stressed not being able to replace it.
Question is : do you have a reference for a spare part, or maybe some links to share for OEM or serious aftermarket ? If it matters, I live in France which may be a reason why it's so hard to find even crawling the Internet US side.
Is there a solution to repair this seal without replacing it, let's say as an interim fix, such as filling it with liquid rubber or so ?
in advance, many thanks for any help.
Leto.
Old Jun 24, 2024 | 01:06 PM
finall's Avatar
Bonjour mon ami.
Try Steele Rubber Products in the USA. You may be able to find something that might work there. If you do, let everyone know!
Old Jul 8, 2024 | 03:40 AM
leto49's Avatar
Hi finall,
I'll search for these products specs and see if they are available in France, otherwise maybe a similar product.
i'll keep you posted.
Old Jul 8, 2024 | 08:17 PM
Mark R's Avatar
Originally Posted by leto49
Hello,
Leto.
Good to see that the HUMMER H2 is alive and well in France. Welcome aboard.
Did a quick search in the USA Amazon site... Found some stuff. Did not go beyond page 1
Amazon Amazon
ALSO:
https://hummer4x4offroad.com/forum/t...acement.11274/
And this looks like a winner: USA Ebay But it says for H3.?? Might be the same??
https://www.ebay.com/itm/15532483925...Bk9SR5zvp9GSZA
Some more From Ebay. I would keep searching Ebay USA.
https://www.infotodiscover.com/web?a...5-166140371427
Old Jan 27, 2025 | 09:42 AM
sarmmerna's Avatar
I had a similar issue with my H2 a while back. Steele Rubber Products is definitely worth checking out—they might ship to France. Also, eBay or Amazon often have universal sunroof seals that could work. For now, liquid rubber or silicone sealant can help as a temporary fix to prevent leaks. By the way, if you're exploring options locally, this guide might help you find resources or shops in France: https://gowithguide.com/France Good luck!
zenith
Nov 5, 2021 05:58 PM
BobV
Apr 23, 2020 10:57 AM
Treina
Apr 12, 2017 10:43 AM
CWC
May 26, 2014 07:42 AM
vinny
Jun 29, 2010 04:25 PM
