Fuel smell inside cabin
Old 08-23-2021, 12:21 PM
mpulsev10's Avatar
Default Fuel smell inside cabin
Gas smell inside cabin, anyone dealt with this before??
Old 08-23-2021, 03:59 PM
I think there is a TSB about that. I'll see if I can find it in the GM eSI system...
Old 08-23-2021, 04:12 PM
Well - I did not see anything. Quite possible I was thinking of a different vehicle. What I remember of it though is that there was some lower body seam poorly sealed that was near the vapor canister but again, that might have been for a different vehicle.
I'd check for any sort of fuel leaks with the engine running (so the fuel system is pressurized). Could be on top of the fuel tank though which is not easy to get to.
Old 08-23-2021, 04:48 PM
it could be the top of your fuel pump has rotted and has holes. does it smell near the driver side passenger door?
Old 08-23-2021, 07:08 PM
There's an easy way to find the source.
Old 08-24-2021, 06:08 AM
oceanbrave's Avatar
An easy way to check your fuel pump in less than 2 minutes.
Reach in to the fuel pump just in front of the left rear wheel arch plastic lining. You should be able to touch all the pipes and rim of the pump etc, if there's a fuel leak you'll feel the damp fuel and smell on your fingers!
Old 08-24-2021, 08:15 AM
mpulsev10's Avatar
can i put it on your insurance policy first with me as the payee ??
Old 08-24-2021, 08:16 AM
mpulsev10's Avatar
Its all brand new, will put on lift and check, just crazy its getting into cabin.
Old 08-24-2021, 10:49 AM
so if you can... recheck all the connectors and lines. maybe one of the fuel lines has a leak.
Old 08-24-2021, 10:50 AM
mpulsev10's Avatar
Thanks everyone it was an injector rail crossover pipe oring. Mechanic recently replaced the knock sensors and i guess boogered or used incorrect seal.
Quick Reply: Fuel smell inside cabin
