It finally happened...
Old Aug 12, 2020 | 02:26 PM
hummer_on_fumes's Avatar
Default It finally happened...
I was hauling a trailer and the brakes turned to mush - the scariest thing ever. Luckily I was on a back road and was able to pull over into someones yard. I had it towed but don't know the diagnosis yet. I'm pretty sure I saw leaking when they put it on the tow truck so my guess is the brake line rusted through or pinched some how. The funny part is at my next oil change that I was about to schedule I was going to have them visibly inspect the brake lines because I know what a common issue this is due to the forums. Then my brakes go out before I set it up!
Old Aug 12, 2020 | 02:30 PM
has the fuel pump been done?
Old Aug 12, 2020 | 02:31 PM
not sure about the PO but I haven't
Old Aug 13, 2020 | 12:22 PM
oceanbrave's Avatar
hummer_on_fumes I can relate to that feeling of being scared. Glad you're OK
My front-left went 2 years ago, last December the rear-right burst, next day the rear-left then Master Cylinder line 1.
The gods were trying to tell me something the 1st time, but I wasn't listening, finally I got the message
Old Aug 13, 2020 | 12:35 PM
This must only be an issue on ones that have been near the coast or northern cities where they salt the roads. I've checked and on my 2003 the brake lines still look great. Bummer to hear of so many having issues with them failing.
Old Aug 14, 2020 | 06:08 AM
oceanbrave's Avatar
In winter, thousands of tons of rock salt are applied to UK roads, a little ice and snow here and the country comes to a stand-still. No wonder our cars and trucks rot so badly
Old Aug 14, 2020 | 10:30 AM
mcu's Avatar
mcu
I am in the process of doing mine now along with the fuel pump. I ordered stainless steel kit from sstubes. Waiting to get them early next week. If you have any questions...glad to help if I can. Check youtube...Oceanbrave put on some great videos on brake lines and fuel pump install.
For those that went through the same with their rusted out brake lines, did you also replace fuel lines with stainless?
Old Aug 14, 2020 | 01:48 PM
oceanbrave's Avatar
mcu yes indeed the fuel lines are a concern as it's likely these are also corroded.
If you decide to replace yours please post any info, it would be very much appreciated.
Good luck with SS upgrade
Old Aug 17, 2020 | 10:37 AM
verdict from my mechanic: 2 of the lines from the abs module rusted and burst... having them replaced
Old Aug 17, 2020 | 10:55 AM
oceanbrave's Avatar
hummer_on_fumes hope this is all of them, if not please "bite the bullet" you're a valued member of this forum!
Plane225
Jul 6, 2020 05:59 AM
ENASNI
Oct 13, 2019 03:16 PM
ChadB
Oct 7, 2014 04:51 PM
Spongebob3971
Oct 14, 2012 09:35 PM
sns
Jun 1, 2010 07:42 AM
