Expected MAF readings
Old Feb 17, 2019 | 08:37 PM
legerwn's Avatar
without the MAF sensor info feeding back to the ECM it will stay in open loop,
When you crank the truck it is in open loop (speed density) until the temp gets above somewhere around 130* then it goes to closed loop and starts using the 02 sensors feed back for adjustments.
leaving the 02 sensors unplug or the MAF sensor unplug with force it to stay in open loop.
Neal
Old Feb 18, 2019 | 09:54 AM
Hbrezzi's Avatar
Thank you Neal!
I tried and the truck got a lot worse. Almost undrivable...
Old Feb 19, 2019 | 09:30 AM
legerwn's Avatar
Need to figure out why it won't run in open loop. Airflow at idle is low, from what I've seen should be around 6.5 to 8 g/s when warm and A/C turned off. What's the manifold pressure at idle? Does it still have the cats on it? Will your scanner read knock retard?
Neal
Hbrezzi
Oct 16, 2018 06:44 PM
dan385
Jul 22, 2018 08:57 PM
ethan1893
Jun 23, 2017 07:22 PM
Raffi76
Mar 11, 2015 02:05 PM
peteschantz
Dec 25, 2007 02:07 AM
