Engine won’t start after rebuild
Old Jul 1, 2022 | 06:03 PM
Mood227's Avatar
Default Engine won’t start after rebuild
Hey y’all! I have a 2007 H2 that had a main oil seal failure, so my dad and I decided to have the entire engine rebuilt and had the cylinders rebored. After replacing other older looking parts, we recently got it into a starting state, but it won’t start. We have confirmed the starter works, but the belt pulley moves the belt about 2 inches and then stops and then starts after about half a second. Is there an issue with how the transmission is mounted? Thank you,
-Joe
attached is the video of car ignition
Old Jul 1, 2022 | 07:15 PM
Old Jul 1, 2022 | 07:53 PM
hopefully they did not leave a rag stuffed in a cylinder. pull the plugs and check.
Old Sep 19, 2022 | 01:26 PM
chaos06's Avatar
Default No rags in cylinder
The heads were done separately and we put them on the block.
It seems electrical, like there is a sensor we may have missed. Cam position sensor, crank position sensor are all new.
could this be the gas pedal sensor that controls the throttle body?
559H3
Sep 8, 2020 08:59 AM
Sushi Boy
Jan 14, 2019 05:08 PM
gotafish
May 18, 2012 05:56 PM
2L8IWON
Feb 25, 2012 09:22 AM
gotafish
Dec 5, 2011 10:22 PM
