Engine starts when ignition is in the on position
Old Jan 4, 2019 | 02:28 PM
Cashville's Avatar
Default Engine starts when ignition is in the on position
Hello. I got an h2 that tries to start the engine when the ignition is in the on position (second position). I've tried another ignition switch, the problem persisted. The problem sometimes goes away, and sometimes it comes back, it's inconsistent.
I've noticed that when the shifter is in the Neutral position, the problem does not happen, the car starts normally only when it should, in the 3rd position. But when I put it in Park, put the keys in and go to the second position the car tries to start, when it shouldn't.
I've isolated the problem only to this part (where in neutral it behaves like it should, and in Park sometimes it behaves normally other times it tries to start in 2nd position).
Anyone knows where the problem might be?
Regards
myrddin
Jun 2, 2019 06:27 PM
ScottAllen
Feb 10, 2019 08:00 AM
AR15wheeler
Apr 20, 2015 09:29 PM
Widespread Hummer
Aug 1, 2012 10:03 AM
Big D
Aug 22, 2009 06:44 PM
